  • Use FTP or SFTP to transfer the OVA image to the /var/lib/insight/packages/ directory on the switch.
Perform the following procedure to configure the package information to be used by the virtual service.
  1. In the navigation pane, expand Configuration > Serviceability.
  2. Select Virtual Service.
  3. Select the Application tab.
  4. Select Insert.
  5. In Name, type the virtual service name.
  6. Next to PackageName, select the ellipsis, select the package to install, and then select Ok.
  7. Select Insert.
Application Field Descriptions
Use data in the following table to use the Application tab.
Name
Description
Name
Specifies the name of the virtual service.
PackageName
Specifies the name and location of the package.
InstallResult
Shows the status of the virtual service installation.
InstallStage
Shows the stages of a package installation.
PackageAppName
Shows the application name used by the virtual service.
PackageAppVersion
Shows the application version used by the virtual service.
